Papa Bear
Post by Papa Bear »
Removable bulkhead?
Black
Marmite lover!!!
VCDS
Caddy46
Post by Caddy46 »
What mm plywood are people using for the door and boot covers? Got some 3mm backing alacantara to cover them?
Papa Bear
Post by Papa Bear »
Audi internal door handle lights finished and coded
Dash Caddy wired in :D
Will take better photos tonight.
Black
Marmite lover!!!
VCDS
pete3dmunds
Post by pete3dmunds »
Doc wrote:Hmmm, I'm intrigued...
Mounting something behind the upper B pillar trim or deleting the bulkhead?
It's for a coat hanger ImageImageImage
I'm fitting the caddy life plastics and have a hole in the plastics where the factory coat hanger goes
Sent from my Pixel 2 using Tapatalk
Papa Bear
Post by Papa Bear »
Well pleased with Audi handle lights. Come on with headlights. Need to see if I can get coming home etc lights working.
Dash Caddy looks brighter in photo than in real life. It’s linked to foot lights so goes on with door opening. Not on all the time.
Black
Marmite lover!!!
VCDS
ViralEye
Post by ViralEye »
I thought about giving the door handle light things a go as I had a full Audi for card set bit sold it all in the end... Need to find some more and give this a go
Craig Cheatham
Post by Craig Cheatham »
Blue lights look superb, great work Pappa!
Now remapped to 145 BHP
Papa Bear
Post by Papa Bear »
Got mine from scrappy, got all the bits rather than having to buy them separately from Audi at £55
Black
Marmite lover!!!
VCDS
Katiecaddy
Post by Katiecaddy »
@pete3dmunds
I’ve been looking for those exact parts for ours for a while so that I can fit our coat hangers,
I don’t suppose you have the part number fo4 them?
Katie
Beaker2135
Post by Beaker2135 »
Swapped out the standard spare wheel for a 16” one, the wider tyre made the carrier a bit to tight for comfort so I dropped a 14mm nut over the bolts to act as a spacer
Vdub-si
Post by Vdub-si »
Fitted black roof rails and a new high level brake light to my 09 caddy
Tum-yeto
Post by Tum-yeto »
Stripped the rest of the ply and OEM boards, removed headliner and bulkhead and gave it a good clean.
Ryzar1
Post by Ryzar1 »
Hey guys just fitted and wired new fog lights today fleebay specials they came with a loom and relay I’ve seen quite a few posts on here about installation I read somewhere that the wire for the switch has to be put into the number 10 pin on the back of the rotary switch ( provided you have the switch that has front and rear fog light options) much frustration found out that it’s the number 7 pin not number 10Image
Ryzar1
Post by Ryzar1 »
Trying to remove the tow bar and put the original crash bar back on......I’m stumped I’ve removed every bolt I can see and the bloody won’t budge any suggestions Image
Ryzar1
Post by Ryzar1 »
