Dubbsley
Post by Dubbsley »
ACalamita wrote: Sat Sep 19, 2020 7:31 pm Cool!
That's pretty much what I understood it's use for. Kinda the known adaptations/long coding changes.
Can you "backup" the long code/config prior to re-writing or is it just like tick boxes?
It’s pretty much a tick box style, tick what you want each time & then hit save, if you don’t like it untick it hit save again & then your back to how it started.
pete3dmunds
Post by pete3dmunds »
Fitted my fork axle mount in the van
Rigguz
Post by Rigguz »
Looks great, which mount is it?? I’m still undecided which to get for mine!
thecolourpurple
Post by thecolourpurple »
Fitted the half leather A3 S line seats & Touran bases.Image
Pepsi
Post by Pepsi »
Looks good the colour purple. I also have the sline seats in mine and are much more comfortable than the standard seat
Pepsi
Post by Pepsi »
Cleaned the van after 3 months of non stop work.
thecolourpurple
Yes mate loads more support. 100% improvement over standard caddy seats.
Tagllana1
Post by Tagllana1 »
I like the look of those @thecolourpurple !!!!
I've been on the hunt for Audi S Line seats - How easy were these to plug in? Do they have identical wiring to the Caddy seats (Air bag and belt sensor) or did you have to get some customised looms? The A1 are a direct fit as they only have the yellow and black connectors... but I prefer the look of the A3 seats !! :)
thecolourpurple
@Tagllana1. Audi use different plugs so I cut them off & made a connection using bootlace crimps & wago cable connectors. I don't have the airbags connected yet just the belt warning.
pete3dmunds
Rigguz wrote: Sun Sep 20, 2020 12:46 pm Looks great, which mount is it?? I’m still undecided which to get for mine!
I used an Audi Avant boot rail. And the mount is from
https://www.mtbvans.co.uk/fork-mount
The good thing about that mount is it allows you to fit all sorts of forks as it comes with adaptors
Peng
Post by Peng »
Small additions can come together to make a nice difference imo. Wind deflectors, sun strip and out my plate onto the van. Slowly but surely I'll get to where I wanna be hahaImage
eph3
Post by eph3 »
Used foam upholstery cleaner on all my seats. Just bought the van and the seats were a bit dirty and stained. They look great now!
C Chis
Post by C Chis »
Replacement radiator hose arrived this morning to fit around the fans and air con compressor instead of directly across them... Image
Just slightly different....
Cabbs
Post by Cabbs »
[mention]pete3dmunds [/mention]
Looks like a good bit of kit that mate. Presumably the fork mount slides along the runner so your able to mount your bike down the middle or to the side?
Where are they from mate? Cheers
Papa Bear
Post by Papa Bear »
More soldering.
Stereo nearly done.
Needles taken apart and painted, thanks to Doc for the donor ones
Black
Marmite lover!!!
VCDS
