Is there a How2 on swapping needles (getting at them in the first place !!) ?
Lots of hard work doing 44 LEDs
Full respect.
Looking forward to pics ....
Papa Bear
Post by Papa Bear »
Have looked at videos on needle swaps, seems very straight forward.
Remove cluster, remove front, put a piece of masking tape under needle and mark where needle is, gently pry needle up and remove, replace with new.
My cluster is white LED’s so not replacing them. If you have red LED’s then replacing them is a LOT more work and risk.
Black
Marmite lover!!!
VCDS
If you have red needles, they'll be lit with a red LED, if you just fit blue needles over red LEDs you end up with them looking a rather cool purple colour when lit.
Papa Bear
Post by Papa Bear »
i thought I could see white coming from behind the needle. I’m ok changing 4 LED’s on the console just didn’t want to have to replace 104 or however many there are
Black
Marmite lover!!!
VCDS
p1andy
Post by p1andy »
In for MOT today and the old girl sailed through :D
RyBigPlumbs
Post by RyBigPlumbs »
Bought these on the weekend for £100, cleaned them up today and they look great, can’t wait to get some touran bases and get them fitted!!
C Chis
Post by C Chis »
Finished off my air con install, all working just perfect!
Only 2 faults - centre control panel and the compressor relay (type 53), most likely they both failed due to water ingress from sitting in a scrapyard Image both fixed Image
Bring on the hot weather!
Irvine
Post by Irvine »
Got both front shocks and lower ball joint replaced. What a difference driving home!
Dickiefree
Post by Dickiefree »
Fitted a swivel chair base Image
in the caddy today from CJL leisure. Not as easy as they said it was going to be, 8 bolts in half an hour....
more like 4 hours .
Lots off mods, seat base plastics cutting. Locating pin cut off on the rail, edge trimmed on the rails, shaved the bolts to shorten them, and had to make the airbag loom longer. Big thanks to Jim for his help today. Image
anoneamus
Post by anoneamus »
Dickiefree wrote: Fri Aug 21, 2020 11:21 pm Fitted a swivel chair base in the caddy today from CJL leisure.
Nice! Very interested in this, but can't find the part on their website. Do you have any more info? Thanks
Dickiefree
“anoneamus"
Hi there they are selling there kits on eBay UK
Item number 224111537959.
Or if you email the company I’m sure they will send you more info on it
Dickiefree
Sent from my iPhone using Tapatalk[/quote]
gavzzorz
Post by gavzzorz »
When I got my caddy it didn't have an Aircon compressor or a high side hose, got all the parts and fitted them today, vacuumed out the system and filled up. Working ac now and freezing cold ImageImage
Sent from my ONEPLUS A6013 using Tapatalk
55 Caddy 1.9tdi ASZ - Refrofitted Cruse, Projectors, HID, Auto Wipers, Auto Lights, Footwell Lights, Highline Display, MFSW, AL Injectors, GTB1752 turbo and 02Q 6 Speed.
anoneamus
Post by anoneamus »
Dickiefree wrote: Sat Aug 22, 2020 9:07 am Or if you email the company I’m sure they will send you more info on it
Cheers. Found it. 12kg. Not going to be cheap to ship to South Africa!
loglifter
Post by loglifter »
Got mine armrest back from the retrimmers (Optimus Auto Retrimmers, Rutheglen. Top job)and refitted. Couldn’t have done it without the “how to” guideImageImage
