2013 Caddy 2.0TDI 4motion (Norway)
Re: 2013 Caddy 2.0TDI 4motion (Norway)
well.. Corona = campingcaddy.. have made some extention to the dobblefloor so a 2x1,2m bed fits inn.. got some awing solution as well #workinprogress
Sent fra min SM-G973F via Tapatalk
Nice work on the sound deadening! Mad that the AWD ones still run leaf sprung rears!
More camping done.. and a second "tent" bought.. this is microcamping gone bad got 2 big tents that i can "connect" together for lots of space.. then i have a "lightweight" tent for backhatch if i just want mor space for madrass.. if i go alone on a trip i would only use thw awning and thent over that.. tha main tents are caravan half size wintertent.. very strong tent fabric
how i mounted the fiamma f35 pro
I quite like the bulk head you have with the window, not sure ive seen that yet, looking good!
Hi.. Its massive and we are not alowwed to remove it in norway :-(
Great work
Some nice new solutions and novel ideas.
Thanks for posting.
Thanks for posting.
Service on haldex done 100'km
Hi fazerfreak, is it an easy enough job to service the haldex? Mine will need doing this year. Do you know of a how to?
Sent from my SM-J600FN using Tapatalk
buy filter and oil, drain oil and change filter.
Fillnup oil untill full, startup and put in gear so haldex start to work (all wheels move) then topup oil.
10-15min job..
we tryid it after 1'st oil fill resulting in a "weeen " sound from the rear due to lack of oil så topup needed to fill filter.
this is how we did it, do at own risk
10-15min job..
picture of filtercap, the filter i ordered inkluded new cap and screews.
Excellent thank you, top job.
Sorry a few more questions if that's ok,
Is yours a Gen4 Haldex?
What is the part number of the filter? And what oil do you use?
The AT tyres - are you happy with the size? Do they rub anywhere? ET of your wheels?
What brand are they?
Was it much louder?
I´m thinking about having AT tires on my 2013 4-motion as an alternative to lowering it.
Right now it has standard steel 16" wheels and standard height.
Was it much louder?
goodrich 215/65/16 audi rims et43
Not nocided any rub ( but it's close )
Not that loud (doesnt bodder me)
realy happy with them,speedo is close to perfect.
@Greg The Great
edit:checked the filter looked up on reg.number and it's haldex 4
https://www.autodoc.co.uk/vaico/12859717
what you dont do for friends this is the haldex oil used
BW. Haldex Fluid Gen II-V (2000884) 0.8L
Borg Warner Fluid Gen II-V (2000884)
