My ex British Gas conversion
TK2192
Re: My ex British Gas conversion
Post by TK2192 »
Love the setup in the back! done a cracking job there
robblowen
Post by robblowen »
@gingerrob sorry man, I didn't see your question! Good job I spotted your other seatbelt post! You managed to get your seatbelts sorted?
robblowen
Post by robblowen »
@TK2192 cheers man, its getting close to where I want it inside, need to start thinking of the outside next.
gingerrob
Post by gingerrob »
robblowen wrote:@gingerrob sorry man, I didn't see your question! Good job I spotted your other seatbelt post! You managed to get your seatbelts sorted?
Yes thank you glad you posted as I was not happy with the long bolts and wedge washers way of fitting so did a similar thing to you though used a hole saw and some laser cut steel discs to button it back up, bit fiddly but happy with the factory look Image will post some pics on mine when I'm done and happy with it ...
Sent from my ANE-LX1 using Tapatalk
robblowen
Post by robblowen »
@gingerrob nice one, glad you got it sorted dude
richyd711
Post by richyd711 »
robblowen wrote:Got the rear speakers fitted and wired in as well. Decided to change where I located them front inside the rear doors to just behind the rear seats. This makes the sound better and meant the were easier to mount.
Where about did you run your wires for the speakers? Also what size speakers are you running?
Great looking build so far can't wait to see more progress
Reason: reduced the quote
B19WEV
Post by B19WEV »
Some great inspiration here mate, love your work!
Gavrob
Post by Gavrob »
Excellent build.
robblowen
Post by robblowen »
Sorry for not replying lads, I've not touched the van for ages and barely been on the forum either! I ran the wiring along to edge of the roof lining as originally I was going to the upper rear corners, then dropped down inside the c pillars. If you're going to fit them in the same place i would think along the sills/under the step would be a lot less faff. As for size I can't remember off the top of my head, similar to the fronts, may even be the same size? That's for the comments guys, hope its given you all some good ideas!
robblowen
Post by robblowen »
So I finally got a few hours on the van, I touched up a load of stone chips on the bonnet which were annoying me, I've just cut them all back. Should get chance to give it a wash and proper polish tomorrow. It's not perfect but you can kind of see from the pics it looks 10 times better!ImageImage
SimonDBS
Post by SimonDBS »
excellent pics really useful thanks, ive tracked down a floor panel through tps but can't figure ot the part number for the black hinge and brackets to bolt-on can you help please
robblowen
Post by robblowen »
@SimonDBS cheers mate, which bits do you mean, the brackets for the rear seats?
If you're after the brackets for the rear seats everything you need should be on here, I think.
https://volkswagen.7zap.com/en/rdw/cadd ... 883020/#50
robblowen
Post by robblowen »
Finally got around to fitting my door handle illumination. If I'm honest it's not as bright as I was hoping, so I need to have a play about with it, not sure if it's the positioning or something else, but you can't really see the light in your own door handle, only the handle opposite even when turned right up?Image
robblowen
Post by robblowen »
Also picked up some foglights, just need to sort the wiring to get them working, but they definitely freshen up the front end. Next job is to cut and bond the awning rail, just need a couple dry days forecast.Image
kneecap
Post by kneecap »
looking good Rob. Can i ask what rail you are going to use? Looking at a couple different ones recommended by guys on here. Also what product do you use to cut back your bonnet? Mine needs some serious TLC.
