VCDS HELP
VCDS HELP
So i've used vagcom, i have a problem with my passenger control module
01044- control module incorrectly coded
005- no or incorrect basic setting/adaption
Anyone know how to recode or kinda know the problem with it?
i have a savage battery drain, checked the AMP draw with a multimeter and nothing im wondering if this is the problem to my battery drainage issue as i think it could be sending constant power to that module.
Any help would be great!
Re: VCDS HELP
Do you have the free version of vcds or paid up hex-can etc?
Re: VCDS HELP
Can you post the details for the module from the Autoscan?
Part number, coding, etc..
Re: VCDS HELP
@MonkeyBum
I've got the genuine lead
Sent from my NX669J using Tapatalk
Reason: Quote removed and tag added
Re: VCDS HELP
@Doc
Yeah sure I will post up the autoscan tomorrow I have this for the time being. I'm unsure if this would cause my battery drain though
Re: VCDS HELP
If the module is coded for rear doors, it's possible the main BCM is staying "awake" thinking the door is still open.
There's multiple reasons for a battery draining, you're definitely starting in the rite place by resolving any fault codes.
Re: VCDS HELP
So this first ever scan i did i saved this log, the battery was on battery maintainer as I knew it would die and both my rear lights aren't plugged in hence the issue with them and drivers door was open so was the bonnet. other than that everything was shut and off as normal.
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
VIN: WV1ZZZ2KZFX074542 Mileage: 121840km-75707miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000 CVN: EF964091
Coding: 00114014032500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
ROD: EV_ECM16TDI02103L997557L.rod
VCID: 7DA7F6A06D756F53CC7-8028
VINID: 9E606AAAA09BA96A001C414408551BBCAB
2 Faults Found:
7362 - Glow Plug Control Module (J179)
P0684 00 [173] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 120265 km
Date: 2021.12.25
Time: 21:00:25
Engine RPM: 914.50 /min
Normed load value: 28.2 %
Vehicle speed: 0 km/h
Coolant temperature: 22 °C
Intake air temperature: 18 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.085 V
Unlearning counter according OBD: 40
Glow status-STATE_GLOW: 48
Fuel temperature-TFU: 20 °C
Sensor for engine block temperature: raw value-Coolant temperature: 17 °C
6550 - System Voltage
P0563 00 [032] - Too High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 121123 km
Date: 2022.01.07
Time: 00:00:15
Engine RPM: 1016.00 /min
Normed load value: 27.1 %
Vehicle speed: 255 km/h
Coolant temperature: 5 °C
Intake air temperature: 6 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 18.522 V
Unlearning counter according OBD: 17
Sensor for engine block temperature: raw value-Coolant temperature: 5 °C
Engine torque-TQI_SP: 45.19 Nm
Accelerator position: normalized-Accelerator position: 0.00 %
selected gear-DRI: 1
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: 433C400D092903FEC21002E8901BC081A0000020
Shop #: WSC 35110 377 00141
VCID: 045183440E1F1E9B839-8050
3 Faults Found:
00668 - Supply Voltage Terminal 30
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 1
Fault Frequency: 5
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.18
Time: 00:00:19
Freeze Frame:
Count: 2
Count: 2
Count: 12800
Count: 129
Count: 47360
Count: 0
Count: 1023
Count: 0
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 4
Reset counter: 29
Mileage: 121104 km
Time Indication: 0
Date: 2016.05.28
Time: 16:12:51
Freeze Frame:
Count: 7
Count: 1
Count: 4096
Count: 128
Count: 29952
Count: 0
Count: 1023
Count: 0
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 3
Reset counter: 250
Mileage: 120299 km
Time Indication: 0
Date: 2016.05.18
Time: 17:08:02
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 288
Count: 50505
Count: 258
Count: 1285
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 CM HW: 7N0 907 426 CM
Component: AC Manuell H20 0707
Revision: 00001002
Coding: 0010004002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 015F8A50118D0BB3A8F-8054
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 S HW: 5K0 937 086 S
Component: BCM PQ35 M+ 122 0173
Revision: BD122001
Coding: 0128083880251A16008800829400816403517288524F8160648040000040
Shop #: WSC 12345 123 12345
VCID: 44D143444E9FDE9BC39-8010
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 25071 26 0512
Coding: 009795
16 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 71
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:59:51
Freeze Frame:
Term 15 On
Voltage: 8.70 V
ON
OFF
OFF
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 5.40 V
OFF
OFF
OFF
OFF
OFF
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
00987 - Lamp for Brake Light; Left (M9)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
01389 - Tailgate Open Switch (F124)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 94
Reset counter: 71
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 21:02:07
Freeze Frame:
Term 15 Off
Voltage: 12.90 V
OFF
OFF
OFF
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
01501 - Bulb for Blinkers; Rear Left (M6)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
01519 - Bulb for Back-Up Lights; Right (M17)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
01834 - Bulb for Side-Blinkers; Left (M18)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 91
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:11:28
Freeze Frame:
Term 15 On
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
01835 - Bulb for Side-Blinkers; Right (M19)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 93
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:11:28
Freeze Frame:
Term 15 On
Voltage: 11.20 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32961431400039
Coding: 108001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70B9DF942A27123B571-8024
3 Faults Found:
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
[Versorgungsspannung - zu niedrig]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:03
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 48
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
[Funktionseinschränkung durch Überspannung - oberer Grenzwert überschritten]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 48
Mileage: 120753 km
Date: 2021.12.30
Time: 00:00:10
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02Q H07 0013
Revision: -------- Serial number: 003HL00TSLF5
Coding: 000000000000000000000000000000003251
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 35372E8015C57713447-8060
1 Fault Found:
[Powersupply lower threshold fall short of]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 69
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 521 DN HW: 5K0 953 569 AF
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20141106200826
Coding: 5080160000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7BA3F8B873616163F23-802E
3 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 69
Mileage: 120265 km
Date: 2021.12.26
Time: 00:01:55
136193 - Supply voltage
U1012 00 [008] - Voltage too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 121849 km
Date: 2022.01.23
Time: 03:47:15
136194 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:09
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 2K0 920 976 E HW: 2K0 920 976 E
Component: KOMBI H03 0905
Coding: 480800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 333310981BB169236A3-8066
2 Faults Found:
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 33
Reset counter: 71
Mileage: 120753 km
Date: 2021.12.30
Time: 00:00:00
[Supply voltage too low]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 48
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 061114F2001850
Coding: 357401
Shop #: WSC 09550 758 180955
VCID: 7EA5F1AC60F3744BD5D-802A
2 Faults Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 121532 km
Time Indication: 0
Date: 2016.06.07
Time: 23:29:22
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 120753 km
Time Indication: 0
Date: 2016.05.22
Time: 05:51:16
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0905
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DCDFC0CFBE8EB195-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
Shop #: WSC 35110 377 00146
VCID: 71BFDA902DAD1B3358F-8024
4 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 392F22B0355D9373A0F-806C
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 121123 km
Time Indication: 0
Date: 2016.05.30
Time: 00:00:17
Freeze Frame:
Battery Volts: 18.5 V
DU
Temperature: 7.0°C
Torque: -0.089 Nm
Torque: -0.7 Nm
RPM: 0 /min
Drive Current: -19.8 A
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.5 V
PD
Temperature: 18.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Component: Tuer-SG 009 2106
Coding: 0008752
VCID: 48C957747EB7FAFB2F1-801C
5 Faults Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
01044 - Control Module Incorrectly Coded
005 - No or Incorrect Basic Setting / Adaptation
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: RCD310 EU H06 5007
Revision: -----10S Serial number: VWZ4Z2P1415089
Coding: 05000200010013
VCID: 72BDD59C24AB202BA15-8026
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Time Indication: 0
Date: 2016.05.30
Time: 02:20:06
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666877329
Coding: 0A01010000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C213BA436EFA65BBB9-8068
3 Faults Found:
[Klemme 30: unterer Grenzwert unterschritten]
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:09
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 48
Mileage: 120753 km
Date: 2021.12.30
Time: 04:40:17
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Mileage: 121123 km
Date: 2022.01.07
Time: 00:00:00
End----------(Elapsed Time: 00:58, VBatt start/end: 12.1V/12.0V)-----------
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 120265 km
Date: 2021.12.25
Time: 21:00:25
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 121123 km
Date: 2022.01.07
Time: 00:00:15
Revision: 00H46001
3 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.18
Time: 00:00:19
Freeze Frame:
Count: 2
Count: 2
Count: 12800
Count: 129
Count: 47360
Count: 0
Count: 1023
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 29
Mileage: 121104 km
Time Indication: 0
Date: 2016.05.28
Time: 16:12:51
Freeze Frame:
Count: 7
Count: 1
Count: 4096
Count: 128
Count: 29952
Count: 0
Count: 1023
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 250
Mileage: 120299 km
Time Indication: 0
Date: 2016.05.18
Time: 17:08:02
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 288
Count: 50505
Count: 258
Count: 1285
Count: 0
Revision: 00001002
Coding: 0010004002
Revision: BD122001
Coding: 009795
16 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 71
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:59:51
Freeze Frame:
Term 15 On
Voltage: 8.70 V
ON
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 69
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 5.40 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 94
Reset counter: 71
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 21:02:07
Freeze Frame:
Term 15 Off
Voltage: 12.90 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.55 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 31
Mileage: 121849 km
Time Indication: 0
Date: 2016.06.16
Time: 00:04:38
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 91
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:11:28
Freeze Frame:
Term 15 On
Voltage: 11.25 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 93
Reset counter: 29
Mileage: 120265 km
Time Indication: 0
Date: 2016.05.17
Time: 16:11:28
Freeze Frame:
Term 15 On
Voltage: 11.20 V
ON
ON
OFF
OFF
OFF
Coding: 108001
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:03
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 48
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 48
Mileage: 120753 km
Date: 2021.12.30
Time: 00:00:10
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 69
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 5080160000
3 Faults Found:
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 69
Mileage: 120265 km
Date: 2021.12.26
Time: 00:01:55
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 121849 km
Date: 2022.01.23
Time: 03:47:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:09
Coding: 480800
2 Faults Found:
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 33
Reset counter: 71
Mileage: 120753 km
Date: 2021.12.30
Time: 00:00:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 48
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 357401
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 121532 km
Time Indication: 0
Date: 2016.06.07
Time: 23:29:22
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 36
Mileage: 120753 km
Time Indication: 0
Date: 2016.05.22
Time: 05:51:16
Coding: 000000
Coding: 0131632
4 Faults Found:
Revision: 00H22000
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 121123 km
Time Indication: 0
Date: 2016.05.30
Time: 00:00:17
Freeze Frame:
DU
Temperature: 7.0°C
Torque: -0.089 Nm
Torque: -0.7 Nm
RPM: 0 /min
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
PD
Temperature: 18.0°C
Count: 2
Count: 0
SteerAng n.Init
Coding: 0008752
5 Faults Found:
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Time Indication: 0
Date: 2016.05.30
Time: 02:20:06
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 48
Mileage: 121129 km
Date: 2022.01.07
Time: 02:20:09
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 48
Mileage: 120753 km
Date: 2021.12.30
Time: 04:40:17
U1401 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Mileage: 121123 km
Date: 2022.01.07
Time: 00:00:00
Re: VCDS HELP
I don't even know where to start on that Autoscan, that is one hell of a list of faults.
I'm gonna go out on a limb here and say the 18+ volts showing in one of the modules may possibly have done damage somewhere. Electronics reacts very different to over voltage Vs under voltage.
As for the passenger door control module, try and set the coding as 0132144 and clear all faults, see if the "incorrect coding" comes back.
Re: VCDS HELP
Thanks for the reply, shall try that tomorrow what will that coding do?
Yeah I'm unsure as to why the voltage varies throughout.. might be the cause of the drain?
Re: VCDS HELP
I've just copied coding from a non "incorrect coding" caddy Autoscan. I've not identified the individual bits to work out where yours is wrong but assuming from the part numbers it is from a Touran while your driver's door module is from a Caddy4.
Re: VCDS HELP
Sorry forgot to say it's the passenger side, this van did have the door module changed reckon they put the wrong module in?
Re: VCDS HELP
Yep, the modules are from two different vehicles.
The coding I've given is for the passenger side.
Re: VCDS HELP
I've had a look at my passenger door module and the number on it is 5K0 959 792 it's a 2015 caddy
Will try that recode you've given me tomorrow
