Hey guys got some caddy life rear seats I’ve ordered the reinforcement plate from vw that’s goes on the floor once you expose the foot wells the seats only came with 3 floor fixings looking up on other members topics I think 6 fixings are required can someone confirm this for me any help would be appreciated ( also I’m not using touran pieces just caddy life)
Cheers all.
Rear seats
- robblowen
Re: Rear seats
For the life seats there are 4 front brackets and 3 rear, the front mounting points for the front brackets are on the panel you've ordered, the other 10 holes, you need to drill yourself. I drilled them, painted the raw edges, then fitted spreader plates under the floor. Need to drop the fuel tank partially to get access. I put pictures up on my build thread if you want to check it out.
Re: Rear seats
Ok so I don’t need to order anymore brackets the because I have the 3 small ones already correct?
- robblowen
Re: Rear seats
You need 7 brackets total mate, should look like this.
Re: Rear seats
Hey mate I’m noticing there’s 3 different types of rail there would you have the part numbers for those I have 2 with the angled plate and 2 straight ones I need to order one more straight rail but don’t have the part number for the ones that have the square looking plate attached
Re: Rear seats
Sorry disregard that looking closer they all look the same
Re: Rear seats
is that weld poof primer on that ?
