mesh grill bulkhead
mesh grill bulkhead
Hi everyone! Just bought a Maxi 1.9 TDI -09, which i'm converting into a dog van but i can't for the life of me find a mesh grill bulkhead for vans. I have found a few for Caddy Life though, will these fit in a van? I live in Sweden.
Re: mesh grill bulkhead
The mesh bulkheads where fitting to the Short wheel base Caddy’s. Any bulkhead will fit from years 2003 to 2020.
Have a try searching for those instead.
Hi! Thank you for your reply. I've found a mesh bulkhead for from a caddy maxi 5 seater- 2008, if i understand your reply correctly it will fit my maxi van from 2009? Will it have to be modify it in any way? I have a picture of it with slide bolts in the upper corners but can't seem to upload pics here.
Reason: removed quote
You need to host pictures off site and link here, inuse postimage.org upload there then copy and paste the hotlink for forums address in your post.
Others prefer tapatalk app but it does make it a pain for those that don't use tapatalk imho.
The 5 seater models don’t normally come with a bulkhead in. Are you referring to this part or something else?
That isn’t a standard caddy bulkhead, it’s aftermarket by the looks of it. I’m sure you could make it fit though.
I think the item you require is commonly described as a dog guard.
99.9% of searches for caddy mesh bulkhead will return the standard bulkhead found behind the front seats.
@the swan fiend
Ok thx!
Ok thx!
@Doc
Hi! I live in Sweden so I've used every possibly search Word in swedish and english, I've only found 2 and both are for caddy life, none for vans.
