Caddy 2011 engine conversion completed
Hi guys just to let ya know I finally got my conversion done converted my 2011 cay 1.6 tdi 5 speed to a 2011 cff 2.0 tdi 6 speed only minor wiring to modify now mapped and running sweet 210bhp anyone want to do this conversion and want any info let me know
Re: Caddy 2011 engine conversion completed
Well done mate, sounds fantastic
2011 Maxi Caddy DSG Stealth Camper Van
- Gazmingo
Hi buddy yes i would be interested in this . And how much it all cost in the end?
Thanks in advance
Thanks in advance
Well I brought a accident damaged 2011 golf gt tdi highline for 800 then took engine,gearbox,gear linkage,engine loom with ecu, body control module,clock spring,steering wheel,key chip, and had to just change couple wires on the secondary engine ecu plug for the afm and 02 sensor and just a relay to wire in for fuel pump because they are on the engine for the 2.0 not in tank so if ya can get mk6 golf 2.0 cff with engine then it not bad job to do
Hello Mate! Greetings from Italy.
I would be interested in doing a swap from the 1.6tdi to 2.0tdi engine too.
I would be interested if you remember the pins you changed in the secondary engine ecu plug?
Thanks I would be grateful for the answer. Here in Italy, unfortunately, there are no people so good with car modifications!
Big Dave, I am very keen to know more about this conversion, we have a company van which looks the part but now needs a power plant to help live upto the looks.
I was looking at the PD130 engines but it seems wrong going for an older engine on a 2011 van. So your conversion looks promising. Do you have a contact number so I could give you a call.
Ben
Ben
Hi is all this needed or can you get away with using control modules ect from the caddy ? Or would you say it’s not worth attempting without a donor car?
Reason: removed quote
- DjLoop
Has anyone changed from BMM engine to DFSD?
Would be cool to go for 16v instead of 8v
Running today BMM with
Turbo - GTB1756V
Injectors - 038 130 073 AL
EGR Delete
PDF Delete
Turbo - GTB1756V
EGR Delete
PDF Delete
Vw Caddy 2008 Carrera Cup Showcar/Db Drag/Demo car
1200Ah Winston Lifepo4 Lithium
114kw in Amplifier power
140m 40 x 40 Steel reinforcement
Bullet Proof Glass "14mm"
370a Mechman Alternator
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
038 130 073AL injectors
Turbo GTB1749V
Full Powerflex
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
Hi bigdave.
What wiring did you have to do i have a full donor car which is a seat leon fr tdi 2010.
I know you need to wire in the fuel pump on the engine to a relay any information greatly appreciated
What wiring modifications did you have to do?
Hi all / bigdave,
I’m in the process of doing this conversion have everything fitted and not seeing fuel at the rail.
I’ve not done this wiring modification but sent the ecu away to have all the immob bypassed etc just not getting fuel now.
Any ideas ?
Any ideas ?
The fuel pump is controlled by the ECU, if you've not got it plugged in then the pump won't run.
hey how is everything? I'm in hands with a change from 1.6 to 2.0 CR in an audi a3 8P, I saw that you made this change in the caddy at the installation level what change did you make? ecu 1.6 Siemens, ecu 2.0 Bosch
thanks
thanks
Hi guys i have a 1.6 13 plate caddy high line.
Mileage getting high now. I also have touran 2.0 tdi doner car. Wat I’m asking have I got everything I need to swap engine over cheers
