What cluster do I have
Hi all,
Is anyone able to tell me by looking at the picture which cluster I have? Is this able to have the code changed for digital speedo or do I need to upgrade the cluster itself?
- Dav02
Re: What cluster do I have
I have the same cluster in mine and you won't be able to get the digital speed in the centre. A cluster upgrade will be required.
Perfect! Thank you for the reply! So confusing trying to work out all the different models
Your caddy is a 2012 so yes it can be activated to show the digital speedo like this..
- Dav02
Hmmmm How have you activated that. I have tried and had others try and cannot get that working with my cluster.
If I remember correctly you need to go into
control unit 17 - long coding - country version - select the rest of the world and save.
then with the ignition on click the left side button on the cluster three times tell the km/h flashes then press the right side button on the cluster once so it then changes to shows the vans millage wait tell it stops flashing and that should give you it.
- Dav02
Thanks. I will have a look into it and see if I can get it working.
There is so many different clusters about.....
- Dav02
Worked a treat thanks very much for that info and apologies to original poster for stating incorrect info.
Does anyone offer coding services in or around yorkshire ? Willing to travel if needed
- Nicklouse
Thanks, do you know his details or user name and I’ll try find him ?
