hi my 2006 caddy clocks instruments reset every time i turn off the ignition
i have a good battery reading 12.8v but it still resets evertime
any advice please
thanks
instrument display resets
Re: instrument display resets
You likely have a blown fuse or faulty instrument cluster.
With the ignition off, if you open the door, does the interior light come on and a display on the instrument cluster?
How about if you active the hazard lights without a key in the ignition?
interior light comes on when opening the door but nothing on the instruments and the hazard works as it should
it was the same on the previous cluster
i will have to have a look for a fuse layout and check
thanks
thanks
With the hazards active and ignition off, do they show on the instrument cluster?
Ok, in that case your instrument cluster has either lost its power supply direct from the battery or there is an internal fault.
do you know which fuse it might be ?
thanks
thanks
It's most likely a 5A in the engine bay fuse panel, rear left corner if you are sat in the driver's seat.
excellent Thanks i will have a look and see tomorrow and let you know
Nice one. That's a good result.
