Bls to bkd caddy
Bls to bkd caddy
Hi guys new here so I’ve got a bls caddy and have a touran donor car with a bkd which I will be putting into the caddy. I’ve done some research but getting mixed info of people
So if I put the touran clocks slip ring engine loom and ecu straight into my caddy. What wiring is there needed to do will I still have to for a n75 valve ? Can anyone shed some light as to what wiring is needed
Thanks in advance
Thanks in advance
Re: Bls to bkd caddy
Hi, welcome to the forum.
First up, forget about swapping the slipring, that is absolutely unnecessary.
Step 1: To get the BKD running in place of a BLS, swap the engine, gearbox, engine bay fuse panel, ECU and instrument cluster. You will need to put the original caddy key blade onto the Touran key fob as this will contain the immobiliser transponder to match the instrument cluster.
This will get you running...but you will have a ABS fault due to having a Caddy ABS module and the vehicle data taken from the immobiliser data on the CANbus showing as a Touran.
Step 2: You will be best to then bring the caddy to someone capable of matching the BKD ECU with the original caddy instrument cluster so as to have compatible vehicle data for your ABS. That same person should be capable of matching the Touran instrument cluster to the ECU (which now will have Caddy data onboard) to give you a coolant temperature gauge and whatever else in available on the Touran instrument cluster.
Thanks for the reply
what about the extra wiring and the n75 valve people keep going on about needing Saying it will run but won’t boost or something
Also I’ve get the immobiliser turned off on the touran ecu will I still have to mess about coding the clocks and abs unit. Someone has also told me just to sway the abs pump over of the touran ?
Also when you say change the fues box how come you have to do that are they not the same? If I am using all the wiring and ecu of the donor car will I still have to do the wiring for the boost valve ect if so do you know how I do this?
Reason: Combined two replies in one post
Not sure where you've been getting your information but to me it appears you've been fed a load of waffle, most likely by people who have not done this before.
Your BLS already has an N75, I've no idea why someone would say you need to change wiring.
Your caddy fuse panel has some different fuse positions, it's just easier to swap them over.
ABS pump swap is not straight forward, the Touran module (mk60) has a remote yaw sensor in the cabin which you don't need for your original caddy module (mk70). That plus you'd have to deal with the 26 pin plug versus 47 pin and having to swap those over.
Having the immobiliser off will make the job a little bit easier but there may be complications with insurance once you've completed the conversion, I guess you just have to deal with that now you've already committed to having it turned off.
Yeah I think I’ve been told a bit rubbish haha. So no need for this extra valve or having to cut the wiring looms open ect the guy I spoke to said ones the engine was in it will run but won’t boost unless you moody the looms/ecu to take that n75 valve
It’s more or less plug and play apart from the coding side
I’ve now stripped the touran do I need just the engine wiring loom or do I also need the wiring loom that goes to the fues box in the engine bay ? Or are they the same just the top half of the fues box that’s needed?
Some pics from the bkd going back together today
- C Chis
Looking good!
Just a thought… If you haven’t already got the relevant wiring diagrams it’s worth logging onto Erwin.de, putting in the VIN from your Touran and downloading all the relevant ones, same for your Caddy and then you’ll be able find the difference’s in the wiring/fuse panel.
Have to have a look into it is it expensive to buy? Or is it per vehicle’s vin
- C Chis
Ah, should have said, it’s €9/hour. You should be able to save/print all the diagrams you need as .PDF’s in that time.
Make sure you have both VIN numbers to hand
I will give it a try worth having the info anyway really
Some progress made today while stud for parts. Swapped the alternator mount from the bls to the bkd to house the power steering pump and got the wiring loom and water pipes back on
Anyone able to help me shed some light on this I have my engine in and mounted. All wiring in apart from one 14pin plug what is missing on the caddy loom anyone able to help me out with splicing it in from the touran loom
@Doc
Are you able to shed some light in my wiring for me I’ve hit a brick wall and can’t figure it out
- D1cky
How did you get on with this ?
