My EX BG VR6 3.2 build
Damo2k
Re: My EX BG VR6 3.2 build
Post by Damo2k »
Looks the part mate sounds unreal too
Post by stu_b »
that's a lot of work and craft gone in there
looks and sounds sweet
Sean1066
Post by Sean1066 »
@Damo2k and stu_b thanks guys it sounds a bit different on the video.
Caddy maxi 3.2 VR6 EX BG
My build thread
Wenty93
Post by Wenty93 »
What a build.. new to caddys have learnt alot from reading your about your build seen a few things already on my caddy and given me some inspiration on what to do in the future
Sean1066
Post by Sean1066 »
@Wenty93
Thank you for taking the time to read my build.
I glad you have found inspiration and learned a few things.
My build thread
Sean1066
Post by Sean1066 »
Pick up some cheap Brembo 4 pot calipers for £120. Image
Now I know why I got them so cheap the pistons were seizedImage
After a lot of hard work I managed to free them and removed them all (4 of them were seized so bad I damaged the pistons getting them out).
I cleaned them up and sanded them down. Then gave them a lick of caliper paint I think they turned out not bad but they do need another coat of paint.
Once I get another coat or 2 on I will fit the new seals and pistons.
Then move on to the front ones Brembo 17z should be a lot easier as they are not seized Image
My build thread
Sean1066
Post by Sean1066 »
Some very nice person has done this of my caddy
I think it awesome. There are some very nice people around.
My build thread
Sean1066
Post by Sean1066 »
My build thread
Damo2k
Post by Damo2k »
Nice
Sean1066
Post by Sean1066 »
All this winters hard work is starting to come together now.
Fitted theses this afternoon.
Just got to do the wiring and they will be good to go.
https://youtube.com/shorts/oJExS5DAZAc? ... jZldqlgIrQ
My build thread
Sean1066
Post by Sean1066 »
Front Brembo calipers complete refurbished
First I use a wire wheel to get all the old paint and crusty bit. Got it back to the metal as much as I could.
Then I primed them with caliper primer
Then finished them off with caliper paint.
Then replaced the rubbers
Had a hard decision to make on the caliper stickers. R32 or Brembo
Went for Brembo to match the rears
If I had found R32 small enough for the rears they probably would said R32 not Brembo
My build thread
J_Con
Post by J_Con »
Vans looking class mate
Mate them lights look amazing!!!
Sean1066
Post by Sean1066 »
@J_Con
Thank you for your nice comment.
@gazza31112
They are a bit different s as me the fact that I can change the colours with my phone is awesome
My build thread
Sean1066
Post by Sean1066 »
I’ve now gone from this Image
To this Image
Finally got them on.
My only concern is the fact that the rear stick out a bit but they don’t catch the door.Image
My build thread
