Had a drive out to a local cars and coffee event today with a couple of mates including traitor @Dav02 who decided to take his Fiesta instead of his van.
Toffee delights
- Lister79
Re: Toffee delights
- Dav02
Re: Toffee delights
absolute bell
Unfortunately the van would have been a much slower drive out and certainly no match to two EA888's
I had a fun drive out anyway, can't beat a bit of power...... all under 60mph of course
Re: Toffee delights
Sorry for digging up an old post Chris...
Am I right in saying the all track is different to the standard mk4 bumper? from what I saw on LLLParts it has extra cut outs I'm assuming for the lower spoiler?
I was told the other day you can just fit the lower spoiler from the all track over a standard mk4 which I don't believe to be true
Reason: Quote removed
2012 Caddy 1.6 TDI Match, lowered with Stance+ coilovers and 18“ John Brown steel wheels
- Lister79
Re: Toffee delights
Yeah that’s correct the Alltrack upper has a lot of cutouts in it to accommodate the lower section and splitter.
It might be possible to just cut all the tabs off the Alltrack lower part and bond it on, but it’s not something I looked at, or considered doing so can’t confirm if it’s possible sorry.
Re: Toffee delights
Do you still have a record of the part number?
There are two numbers on LLL Parts for the bumper which are 2K5807417G GRU and 2K5807417F GRU. From their descriptions I'm guessing the G comes without parking sensor holes where as the F does?
But by the looks of your thread the lower all track spoiler requires the parking sensor holes punching through?
Sorry for all the questions...
- Lister79
Re: Toffee delights
G is the correct bumper. The part numbers used can be found here:
https://www.caddy2k.com/forum/viewtopic ... 50#p128050
Yeah you will need to add the parking sensor holes to the lower spoiler section, the specific punch’s make a neat hole and they are pre marked on the back to make things easy.
Re: Toffee delights
More questions, sorry Chris
You don't happen to have a picture of the part number for the heater controls with heated seats? I know you've no longer got this as you have climatronic or what ever its called
- Lister79
Re: Toffee delights
I don’t sorry, but all information for heated seats can be found here:
https://www.caddy2k.com/forum/viewtopic.php?t=22625
