Caddywupz Van Conversion
Re: Caddywupz Van Conversion
Hi caddywupz
May I ask where you got your led strips.
Cheers Dave
Cheers Dave
Good old ebay!Dibsta wrote:Hi caddywupz
Cheers Dave
Although the seller I bought mine from doesn't exist anymore, but there's loads on ebay. I got 3528 LED strip.
Photographer & Caddy Conversion-er
Instagram Photos: neil_irwin
Instagram Caddy: caddywupz
Cheers pal I will take a lookcaddywupz wrote: Good old ebay!
Installed my new rear door handle today. Sure it'll come in useful.
Looks awesome so far. Would love to find out where or what the rear door handle came from. What is the part number?
Hi,
Can I ask how you fixed that ply side panel? Also are you intending to carpet the rear?
Cheers.
Cheers.
Already came in the van by the previous owner, screwed straight in to the van walls where there are raised sections as to not puncture the outer skin. So nothing special - just reusing old screw holes.
Cool project, will keep an eye on this
I'm keen to know about the rear door handle too! Very handy. Can you see a part number on it?
There's already a thread for the rear door handle on here. That's where I got all my part numbers from and called up my local TPS.
Thanks!
Been a while since I've done any work on it. Finally got some time to do some more! Just cut out my vinyl floor and hoping to stick it tomorrow. Once that's done, I Can make a start on building my bed. It's already had some design changes since the initial concept from the drawing, but still very similar.
Finally installed my vinyl floor. I wouldn't recommend using a sharpie to mark on it though... Fail. Looks smart though.
Also got all my trim back in. Can now officially start the design and build the bed.
- Garrigle
That's the same design I want for a bed/couch in my maxi too. Ill keep an eye on this see how it turns out
Design has changed a bit from the initial concept, but it's pretty similar.
Been building the frame today. Hope to get it all together tomorrow and show you all what it loos like.
Fingers crossed my idea has all come together and there's enough clearance in the relevant places...
