Caddy maxi wav
peckerhead
Caddy maxi wav
Post by peckerhead »
Is there any suspension mods I can do but keep the wheelchair ramp as it’s used for a heavy electric wheelchair maybe lower only 30mm.
Scimitar
Re: Caddy maxi wav
Post by Scimitar »
Depends on the way the low floor is installed but I doubt it,
High chance on the floor bottoming out and causing issues of you do..
peckerhead
Re: Caddy maxi wav
If I lower the front would it cause a problem on the back if I leave it stranded.
Mick1972
Re: Caddy maxi wav
Post by Mick1972 »
Many of the WAV’s I’ve come across have air suspension on the rear to lower it so to reduce the ramp angle.
